AW: [Lugbz-list] help!
Ho perso la tua prima mail S2.
Quale è la causa si tutto ciò? Hai cambiato modem?
riposto:
[---INIZIO---]
ciao a tutti. ho un problema da porrvi che non riesco a risolvere e che sta
inizando veramente a farmi girare le balle...
allora: fino a poco tempo fa quando mi connettevo wvdial faceva cosí:
[---snip-snip---]
Mar 2 17:39:54 lsd WvDial: Sending: ATDT 800330149
Mar 2 17:39:54 lsd WvDial: Waiting for carrier.
Mar 2 17:39:54 lsd WvDial: ATDT 800330149
Mar 2 17:40:21 lsd WvDial: CONNECT 50666/ARQ/V90/LAPM/V42BIS
Mar 2 17:40:21 lsd WvDial: Carrier detected. Starting PPP immediately.
Mar 2 17:40:21 lsd pppd[3500]: Serial connection established.
Mar 2 17:40:21 lsd pppd[3500]: Using interface ppp0
Mar 2 17:40:21 lsd pppd[3500]: Connect: ppp0 <--> /dev/modem
Mar 2 17:40:26 lsd pppd[3500]: local IP address 62.122.96.69
Mar 2 17:40:26 lsd pppd[3500]: remote IP address 212.41.192.55
Mar 2 17:40:26 lsd pppd[3500]: primary DNS address 212.41.208.10
Mar 2 17:40:26 lsd pppd[3500]: secondary DNS address 212.41.208.7
Mar 2 17:40:54 lsd ez-ipupdate[683]: successful update for
ppp0->62.122.96.69 (s2-akira.ath.cx)
Mar 2 20:41:26 lsd pppd[3500]: Hangup (SIGHUP)
Mar 2 20:41:26 lsd pppd[3500]: Modem hangup
Mar 2 20:41:26 lsd pppd[3500]: Connection terminated.
Mar 2 20:41:26 lsd pppd[3500]: Connect time 181.1 minutes.
Mar 2 20:41:26 lsd pppd[3500]: Sent 929364 bytes, received 2762670 bytes.
Mar 2 20:41:26 lsd pppd[3500]: Exit.
[---snip-snip---]
bene... ora invece succede questo:
[---snip-snip---]
Mar 9 15:44:35 lsd WvDial: Sending: ATDT 800330149
Mar 9 15:44:35 lsd WvDial: Waiting for carrier.
Mar 9 15:44:35 lsd WvDial: ATDT 800330149
Mar 9 15:44:35 lsd WvDial: WAITING
Mar 9 15:45:30 lsd WvDial: CONNECT 50666/ARQ
Mar 9 15:45:30 lsd WvDial: Carrier detected. Starting PPP immediately.
Mar 9 15:45:30 lsd pppd[1503]: Serial connection established.
Mar 9 15:45:30 lsd pppd[1503]: Using interface ppp0
Mar 9 15:45:30 lsd pppd[1503]: Connect: ppp0 <--> /dev/ttyS1
Mar 9 15:46:01 lsd pppd[1503]: LCP: timeout sending Config-Requests
Mar 9 15:46:01 lsd pppd[1503]: Connection terminated.
Mar 9 15:46:02 lsd pppd[1503]: Hangup (SIGHUP)
Mar 9 15:46:02 lsd pppd[1503]: Exit.
[---snip-snip---]
ho provato a leggere le man del pppd ma niente a riguardo di questo
problema, ho provato a farmi uno script da solo (cioé questo:
/usr/sbin/pppd /dev/ttyS1 57600 debug connect "/usr/sbin/chat -v '' ATZ
OK ATDT800330149 CONNECT '\d\c'"
), ma sempre il solito problema... allora ho pensato porse il mio isp usa
Win NT RAS, e allora ho sostituito '\d\c' con CLIENT, ma niente; sempre quel
messaggino del caxxo che mi persegue e mi riempie il file di log: LCP:
timeout sending Config-Requests ...
bé... aiutatemi voi perché stó iniziando a sklerare...
tnx.
un S2 che non si connette piu con Linux...
[--FINE--]
Il problema e' molto strano, indubbiamente ; dal manuale del pppd e dai tuoi
log al momento mi viene in mente di provare con
lcp-max-configure n
Set the maximum number of LCP configure-request transmissions to n
(default 10)
prova ad alzare il numero di tentativi..giusto per vedere se e' un problema di
timeout; e' solo un test che ti propongo..perche' effettivamente neanche io ci
ho capito molto :))))
Intanto continuo la ricerca.....mi dici come scheduli il pppd (quali parametri)?
                Andy
opssssss..dimenticato un pezzo :
oltre al parametro precedentemente indicato, potrebbe essere utile anche
lcp-max-failure n
Set the maximum number of LCP configure-NAKs returned before starting to send
configure-Rejects instead to n (default 10).
        Bye
                Andy
Atra cosa interessante..anche se forse gia nota :
Authentication must be satisfactorily completed before IPCP (or any
otherNetwork Control Protocol) can be started. If the peer is required
to authenticate itself, and fails to do so, pppd will terminated the link
(by closing LCP). If IPCP negotiates an unacceptable IP address for
the remote host, IPCP will be closed. IP packets can only be sent or
received when IPCP is open.
Sempre presa dal manuale pppd
        Andy
Se nessuno dei suggerimenti funziona, ti consiglio di ricompilare pppd con
l'opzione debug (che non e' la stessa del debug da riga di comando) che
fornisce informazioni aggiuntive..chissa' mai che non dia qualche info
illuminante :wink:
The debug option causes the contents of all control packets sent or
received to be logged, that is, all LCP, PAP, CHAP or IPCP packets.
This can be useful if the PPP negotiation does not succeed or if
authentication fails. If debugging is enabled at compile time, the debug
option also causes other debugging messages to be logged.
        byeZ
                Andy
