Hi LUGBZ,
for some services I started using OTP, at the moment FreeOTP on Android.
Now I am afraid what could happen if I lose the device or if it just breaks.
What is you backup strategy, to be able to access all your services,
which you secured through OTP, after a break or loss of your device?
I am looking for a strategy to avoid disasters
Thanks for any suggestion!
attachment.htm (722 Bytes)
Most services provide you with a series of scratch codes when you set
OTP up on each web site. The codes can usually displayed again at a
later stage from your account page.
For those services that don't give you scratch codes, have a look at
their password recovery help page. Some sites use an alternative email
address, some use phone numbers. Make sure these details are up to date.
I keep the scratch codes along with all my passwords in a gnupg
encrypted file.
Hi Thomas,
Thank you for this information! I will check the websites.
encrypted file.
I see. Thank you.
At the end this means, there is no need for a backup of the OTP app data
itself. It seams also to be impossible to restore a backup on a
different device.
Thank you for this valuable information!
Best regards,
attachment.htm (1.73 KB)
different device.
Hi Patrick,
this is the conclusion I came to. To elaborate, the OTP application I
use (Aegis) has the option to backup the vault on the cloud or to
download it as a file.
The former does not appeal to me (YMMV) and I can see the latter as a
quick way of importing all accounts at once. But I would see this as an
additional measure for convenience, and definitely not as the main (or
only) way to recover the 2FA tokens; always keep an direct, independent
way to regain access to your online services.
Hi Patrick,
andOTP seems to have quite a good backup option\.
Cheers
Andreas
