Postgresql incrementing index on view
Good morning everyone.
I am trying to create a view in postgresql with its own unique incrementing
id.
Problem is I am starting from a union query to have several values of a
record in a one-to-many relation.
Therefore I can't use row_number().
I.e. I am trying to create a view from:
select row_number() over() as id, value1
union
select row_number() over() as id, value2
and I would have the same id for the pair of values.
Also using a sequence won't work, since it will be changing at every
select.
Does anyone know of a way to handle this?
To be honest I do not even think it makes sense from a conceptual point of
view of a 'view'.
But you never know :slight_smile:
Thanks for any idea,
attachment.html (1.02 KB)
Ciao, a solution is:
CREATE VIEW AS
SELECT row_number() over() AS ID,
attachment.html (2.38 KB)
Hi Luca,
CREATE VIEW AS
FROM (
   SELECT ...
  UNION
   SELECT ...
) AS myview;
thanks, that indeed is working.
Cheers,
attachment.html (3.43 KB)
