problema login
Ciao al tutto il Lug.
Forse qualcuno di voi può aiutarmi. Ho installato Mepis 8 su di un Acer
Travelmate 4000. Quando arrivo al login mi da "Failed to execute login
command". Sia utente normale che root. Da shell riesco a loggarmi in
entrambi i modi ma lanciando "startx" mi da questo " Fatal server error".
Grazie
Werner
Un po' poco... prova a inviare le ultime righe di /var/log/messages/ e
il contenuto di /var/log/Xorg.0.log così forse riusciamo ad aiutarti.
Immaginavo, ma volevo evitare di inviare materiale inutile.
Ecco il log di messages:
Oct 16 13:40:19 mepisonia kernel: MC'97 0 converters and GPIO not ready (0x1)
Oct 16 13:40:19 mepisonia kernel: Adding 979956k swap on /dev/hda2. Priority:1 extents:1 across:979956k
Oct 16 13:40:19 mepisonia kernel: EXT3 FS on hda1, internal journal
Oct 16 13:40:19 mepisonia kernel: device-mapper: uevent: version 1.0.3
Oct 16 13:40:19 mepisonia kernel: device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel(a)redhat.com
Oct 16 13:40:19 mepisonia kernel: ndiswrapper version 1.53 loaded (smp=yes, preempt=yes)
Oct 16 13:40:19 mepisonia kernel: usbcore: registered new interface driver ndiswrapper
Oct 16 13:40:19 mepisonia kernel: fuse init (API version 7.9)
Oct 16 13:40:19 mepisonia kernel: kjournald starting. Commit interval 5 seconds
Oct 16 13:40:19 mepisonia kernel: EXT3 FS on hda3, internal journal
Oct 16 13:40:19 mepisonia kernel: EXT3-fs: mounted filesystem with ordered data mode.
Oct 16 13:40:20 mepisonia kernel: NET: Registered protocol family 10
Oct 16 13:40:20 mepisonia kernel: lo: Disabled Privacy Extensions
Oct 16 13:40:20 mepisonia kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 16 13:40:21 mepisonia kernel: lp: driver loaded but no devices found
Oct 16 13:40:21 mepisonia kernel: ppdev: user-space parallel port driver
Oct 16 13:40:27 mepisonia kernel: ttyS1: LSR safety check engaged!
Oct 16 13:40:28 mepisonia powersaved: Starting powersaved with ACPI support
Oct 16 13:40:30 mepisonia kernel: mtrr: no more MTRRs available
Oct 16 13:40:58 mepisonia last message repeated 5 times
E questo è il log di xorg:
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10)
Current Operating System: Linux mepisonia 2.6.27-1-mepis-smp #1 SMP
PREEMPT Sat Feb 7 09:09:58 EST 2009 i686
Build Date: 09 January 2009 02:57:16AM
    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 16 13:40:57 2009
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "XFree86 Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "PS/2 Mouse"
(**) |-->Input Device "Touchpad"
(**) Option "AllowMouseOpenFail" "true"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/truetype/arphic" does not exist.
    Entry deleted from font path.
(WW) The directory "/usr/share/fonts/truetype/kochi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
does not exist.
(==) Including the default font path
/usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
    /usr/share/fonts/X11/100dpi:unscaled,
    /usr/share/fonts/X11/misc:unscaled,
    /usr/share/fonts/truetype/freefont,
    /usr/share/fonts/truetype/ttf-bitstream-vera,
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
    X.Org ANSI C Emulation: 0.3
    X.Org Video Driver: 2.0
    X.Org XInput driver : 2.0
    X.Org Server Extension : 0.3
    X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
    compiled for 1.4.2, module version = 1.0.0
    ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,3580 card 1025,0064 rev 02 class 06,00,00
hdr 80
(II) PCI: 00:00:1: chip 8086,3584 card 1025,0064 rev 02 class 08,80,00
hdr 00
(II) PCI: 00:00:3: chip 8086,3585 card 1025,0064 rev 02 class 08,80,00
hdr 80
(II) PCI: 00:02:0: chip 8086,3582 card 1025,0064 rev 02 class 03,00,00
hdr 80
(II) PCI: 00:02:1: chip 8086,3582 card 1025,0064 rev 02 class 03,80,00
hdr 80
(II) PCI: 00:1d:0: chip 8086,24c2 card 1025,0064 rev 03 class 0c,03,00
hdr 80
(II) PCI: 00:1d:1: chip 8086,24c4 card 1025,0064 rev 03 class 0c,03,00
hdr 00
(II) PCI: 00:1d:2: chip 8086,24c7 card 1025,0064 rev 03 class 0c,03,00
hdr 00
(II) PCI: 00:1d:7: chip 8086,24cd card 1025,0064 rev 03 class 0c,03,20
hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev 83 class 06,04,00
hdr 01
(II) PCI: 00:1f:0: chip 8086,24cc card 0000,0000 rev 03 class 06,01,00
hdr 80
(II) PCI: 00:1f:1: chip 8086,24ca card 1025,0064 rev 03 class 01,01,8a
hdr 00
(II) PCI: 00:1f:3: chip 8086,24c3 card 1025,0064 rev 03 class 0c,05,00
hdr 00
(II) PCI: 00:1f:5: chip 8086,24c5 card 1025,0064 rev 03 class 04,01,00
hdr 00
(II) PCI: 00:1f:6: chip 8086,24c6 card 1025,0064 rev 03 class 07,03,00
hdr 00
(II) PCI: 02:02:0: chip 14e4,4401 card 1025,0064 rev 01 class 02,00,00
hdr 00
(II) PCI: 02:04:0: chip 8086,4220 card 8086,2701 rev 05 class 02,80,00
hdr 00
(II) PCI: 02:06:0: chip 104c,8031 card 3000,0000 rev 00 class 06,07,00
hdr 82
(II) PCI: 02:06:2: chip 104c,8032 card 1025,0064 rev 00 class 0c,00,10
hdr 80
(II) PCI: 02:06:3: chip 104c,8033 card 1025,0064 rev 00 class 01,80,00
hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
    [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
    [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,6), BCTRL: 0x0004 (VGA_EN is
cleared)
(II) Bus 2 I/O range:
    [0] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
    [1] -1 0 0x00003400 - 0x000034ff (0x100) IX[B]
    [2] -1 0 0x00003800 - 0x000038ff (0x100) IX[B]
    [3] -1 0 0x00003c00 - 0x00003cff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
    [0] -1 0 0xe0200000 - 0xe05fffff (0x400000) MX[B]
(II) Bus 2 prefetchable memory range:
    [0] -1 0 0x20000000 - 0x25ffffff (0x6000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 3: bridge is at (2:6:0), (2,3,6), BCTRL: 0x05c0 (VGA_EN is cleared)
(II) Bus 3 I/O range:
(II) Bus 3 prefetchable memory range:
    [0] -1 0 0x20000000 - 0x23ffffff (0x4000000) MX[B]
(--) PCI:*(0:2:0) Intel Corporation 82852/855GM Integrated Graphics
Device rev 2, Mem @ 0xe8000000/27, 0xe0000000/19, I/O @ 0x1800/3
(--) PCI: (0:2:1) Intel Corporation 82852/855GM Integrated Graphics
Device rev 2, Mem @ 0xf0000000/27, 0xe0080000/19
(II) Addressable bus resource ranges are
    [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
    [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
    [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
    [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
    [0] -1 0 0xe0206000 - 0xe0207fff (0x2000) MX[B]
    [1] -1 0 0xe0200000 - 0xe0203fff (0x4000) MX[B]
    [2] -1 0 0xe020a000 - 0xe020a7ff (0x800) MX[B]
    [3] -1 0 0xe0208000 - 0xe0208fff (0x1000) MX[B]
    [4] -1 0 0xe0204000 - 0xe0205fff (0x2000) MX[B]
    [5] -1 0 0xe0100800 - 0xe01008ff (0x100) MX[B]
    [6] -1 0 0xe0100c00 - 0xe0100dff (0x200) MX[B]
    [7] -1 0 0x26000000 - 0x260003ff (0x400) MX[B]
    [8] -1 0 0xe0100000 - 0xe01003ff (0x400) MX[B]
    [9] -1 0 0xe0080000 - 0xe00fffff (0x80000) MX[B](B)
    [10] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [11] -1 0 0xe0000000 - 0xe007ffff (0x80000) MX[B](B)
    [12] -1 0 0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
    [13] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
    [14] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
    [15] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
    [16] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
    [17] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
    [18] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
    [19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [21] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [22] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [23] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
    [24] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
    [25] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
    [26] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
    [0] -1 0 0x00100000 - 0x25ffffff (0x25f00000) MX[B]E(B)
(II) All system resource ranges:
    [4] -1 0 0xe0206000 - 0xe0207fff (0x2000) MX[B]
    [5] -1 0 0xe0200000 - 0xe0203fff (0x4000) MX[B]
    [6] -1 0 0xe020a000 - 0xe020a7ff (0x800) MX[B]
    [7] -1 0 0xe0208000 - 0xe0208fff (0x1000) MX[B]
    [8] -1 0 0xe0204000 - 0xe0205fff (0x2000) MX[B]
    [9] -1 0 0xe0100800 - 0xe01008ff (0x100) MX[B]
    [10] -1 0 0xe0100c00 - 0xe0100dff (0x200) MX[B]
    [11] -1 0 0x26000000 - 0x260003ff (0x400) MX[B]
    [12] -1 0 0xe0100000 - 0xe01003ff (0x400) MX[B]
    [13] -1 0 0xe0080000 - 0xe00fffff (0x80000) MX[B](B)
    [14] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [15] -1 0 0xe0000000 - 0xe007ffff (0x80000) MX[B](B)
    [16] -1 0 0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
    [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    [19] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
    [20] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
    [21] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
    [22] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
    [23] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
    [24] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
    [25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [29] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
    [30] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
    [31] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
    [32] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
(II) "extmod" will be loaded. This was enabled by default and also
specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also
(II) "glx" will be loaded. This was enabled by default and also
(II) "freetype" will be loaded. This was enabled by default and also
(II) "record" will be loaded by default.
(II) "dri" will be loaded. This was enabled by default and also
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
    Module class: X.Org Server Extension
    ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
    compiled for 1.4.2, module version = 2.1.0
    Module class: X.Org Font Renderer
    ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "type1"
(WW) Warning, couldn't open module type1
(II) UnloadModule: "type1"
(EE) Failed to load module "type1" (module does not exist, 0)
(II) LoadModule: "v4l"
(II) Loading /usr/lib/xorg/modules/drivers//v4l_drv.so
(II) Module v4l: vendor="X.Org Foundation"
    compiled for 1.4.0.90, module version = 0.1.1
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
    compiled for 1.4.2, module version = 1.1.0
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
    compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
    compiled for 1.4.0, module version = 1.3.0
    Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
    compiled for 1.4.0.90, module version = 1.3.1
    Module class: X.Org XInput Driver
    ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
    compiled for 1.4.0.90, module version = 1.3.0
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
    compiled for 4.3.99.902, module version = 1.0.0
(II) v4l driver for Video4Linux
(II) VESA: driver for VESA chipsets: vesa
(II) Primary Device is: PCI 00:02:0
(--) Assigning device section with no busID to primary device
(--) Chipset vesa found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
    [17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
    [18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
    [19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
    [20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
    [21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
    [22] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
    [23] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
    [24] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
    [25] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
    [26] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
    [27] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
    [28] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [29] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [30] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
    [31] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
    [32] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
    [33] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
    [34] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
    [35] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
    [36] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
    [37] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules//libvbe.so
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) VESA(0): initializing int10
(WW) VESA(0): Bad V_BIOS checksum
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 3.0
(II) VESA(0): VESA VBE Total Mem: 16192 kB
(II) VESA(0): VESA VBE OEM: Intel(r)852GM/852GME/855GM/855GME Graphics
Chip Accelerated VGA BIOS
(II) VESA(0): VESA VBE OEM Software Rev: 1.0
(II) VESA(0): VESA VBE OEM Vendor: Intel Corporation
(II) VESA(0): VESA VBE OEM Product: Intel(r)852GM/852GME/855GM/855GME
Graphics Controller
(II) VESA(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(**) VESA(0): Depth 16, (--) framebuffer bpp 16
(==) VESA(0): RGB weight 565
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) VESA(0): VESA VBE DDC supported
(II) VESA(0): VESA VBE DDC Level 2
(II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
(II) VESA(0): VESA VBE DDC read successfully
(II) VESA(0): Manufacturer: HTC Model: dd Serial#: 1030166551
(II) VESA(0): Year: 2004 Week: 43
(II) VESA(0): EDID Version: 1.3
(II) VESA(0): Digital Display Input
(II) VESA(0): Max H-Image Size [cm]: horiz.: 33 vert.: 21
(II) VESA(0): Gamma: 2.20
(II) VESA(0): No DPMS capabilities specified
(II) VESA(0): First detailed timing is preferred mode
(II) VESA(0): redX: 0.590 redY: 0.330 greenX: 0.300 greenY: 0.550
(II) VESA(0): blueX: 0.140 blueY: 0.130 whiteX: 0.310 whiteY: 0.330
(II) VESA(0): Manufacturer's mask: 0
(II) VESA(0): Supported Future Video Modes:
(II) VESA(0): #0: hsize: 1280 vsize 800 refresh: 60 vid: 129
(II) VESA(0): Supported additional Video Mode:
(II) VESA(0): clock: 71.0 MHz Image Size: 331 x 207 mm
(II) VESA(0): h_active: 1280 h_sync: 1328 h_sync_end 1360 h_blank_end
1440 h_border: 0
(II) VESA(0): v_active: 800 v_sync: 802 v_sync_end 808 v_blanking: 823
v_border: 0
(II) VESA(0): Hitachi
(II) VESA(0): TX39D85VC1FA
(II) VESA(0): EDID (in hex):
(II) VESA(0): 00ffffffffffff002283dd001718673d
(II) VESA(0): 2b0e0103802115781a2fd697544c8c23
(II) VESA(0): 214f5400000081000101010101010101
(II) VESA(0): 010101010101bc1b00a0502017303020
(II) VESA(0): 26004bcf100000190000000f00202020
(II) VESA(0): 2020202020a0ff023200000000fe0020
(II) VESA(0): 202020204869746163686900000000fe
(II) VESA(0): 005458333944383556433146410000b5
(II) VESA(0): EDID vendor "HTC", prod id 221
(II) VESA(0): Printing DDC gathered Modelines:
(II) VESA(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800
802 808 823 -hsync -vsync (49.3 kHz)
(II) VESA(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800
803 809 831 -hsync +vsync (49.7 kHz)
(II) VESA(0): Searching for matching VESA mode(s):
Mode: 160 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    GreenFieldPosition: 0
    BlueMaskSize: 0
    BlueFieldPosition: 0
    RsvdMaskSize: 0
    RsvdFieldPosition: 0
    DirectColorModeInfo: 0
    PhysBasePtr: 0x0
    LinBytesPerScanLine: 0
    BnkNumberOfImagePages: 0
    LinNumberOfImagePages: 0
    LinRedMaskSize: 0
    LinRedFieldPosition: 0
    LinGreenMaskSize: 0
    LinGreenFieldPosition: 0
    LinBlueMaskSize: 0
    LinBlueFieldPosition: 0
    LinRsvdMaskSize: 0
    LinRsvdFieldPosition: 0
    MaxPixelClock: 0
Mode: 161 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 162 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 163 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 164 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 165 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 166 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 167 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 168 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 169 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16a (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16b (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16c (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16d (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16e (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 16f (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 170 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 171 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 17c (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 17d (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 17e (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 13c (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 14d (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 15c (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 13a (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 14b (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 15a (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 107 (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 11a (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 11b (0x0)
    ModeAttributes: 0x0
    WinAAttributes: 0x0
    WinBAttributes: 0x0
    WinGranularity: 0
    WinSize: 0
    WinASegment: 0x0
    WinBSegment: 0x0
    WinFuncPtr: 0x0
    BytesPerScanline: 0
    XResolution: 0
    YResolution: 0
    XCharSize: 0
    YCharSize: 0
    NumberOfPlanes: 0
    BitsPerPixel: 0
    NumberOfBanks: 0
    MemoryModel: 0
    BankSize: 0
    NumberOfImages: 0
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0x0
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 0
Mode: 105 (1024x768)
    ModeAttributes: 0x9b
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    WinFuncPtr: 0xc0007002
    BytesPerScanline: 1024
    XResolution: 1024
    YResolution: 768
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 8
    NumberOfBanks: 1
    MemoryModel: 4
    BankSize: 0
    NumberOfImages: 20
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    PhysBasePtr: 0xe8000000
    LinBytesPerScanLine: 1024
    BnkNumberOfImagePages: 20
    LinNumberOfImagePages: 20
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
    MaxPixelClock: 230000000
*Mode: 117 (1024x768)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 2048
    XResolution: 1024
    YResolution: 768
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 16
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 9
    RedMaskSize: 5
    RedFieldPosition: 11
    GreenMaskSize: 6
    GreenFieldPosition: 5
    BlueMaskSize: 5
    RsvdMaskSize: 0
    LinBytesPerScanLine: 2048
    BnkNumberOfImagePages: 9
    LinNumberOfImagePages: 9
    LinRedMaskSize: 5
    LinRedFieldPosition: 11
    LinGreenMaskSize: 6
    LinGreenFieldPosition: 5
    LinBlueMaskSize: 5
    LinRsvdMaskSize: 0
Mode: 118 (1024x768)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 4096
    XResolution: 1024
    YResolution: 768
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 32
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 4
    RedMaskSize: 8
    RedFieldPosition: 16
    GreenMaskSize: 8
    GreenFieldPosition: 8
    BlueMaskSize: 8
    RsvdMaskSize: 8
    RsvdFieldPosition: 24
    LinBytesPerScanLine: 4096
    BnkNumberOfImagePages: 4
    LinNumberOfImagePages: 4
    LinRedMaskSize: 8
    LinRedFieldPosition: 16
    LinGreenMaskSize: 8
    LinGreenFieldPosition: 8
    LinBlueMaskSize: 8
    LinRsvdMaskSize: 8
    LinRsvdFieldPosition: 24
Mode: 112 (640x480)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 2560
    XResolution: 640
    YResolution: 480
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 32
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 12
    RedMaskSize: 8
    GreenMaskSize: 8
    BlueMaskSize: 8
    RsvdMaskSize: 8
    LinBytesPerScanLine: 2560
    BnkNumberOfImagePages: 12
    LinNumberOfImagePages: 12
    LinRedMaskSize: 8
    LinGreenMaskSize: 8
    LinBlueMaskSize: 8
    LinRsvdMaskSize: 8
*Mode: 114 (800x600)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 1600
    XResolution: 800
    YResolution: 600
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 16
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 15
    RedMaskSize: 5
    GreenMaskSize: 6
    BlueMaskSize: 5
    RsvdMaskSize: 0
    LinBytesPerScanLine: 1600
    BnkNumberOfImagePages: 15
    LinNumberOfImagePages: 15
    LinRedMaskSize: 5
    LinGreenMaskSize: 6
    LinBlueMaskSize: 5
    LinRsvdMaskSize: 0
Mode: 115 (800x600)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 3200
    XResolution: 800
    YResolution: 600
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 32
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 7
    RedMaskSize: 8
    GreenMaskSize: 8
    BlueMaskSize: 8
    RsvdMaskSize: 8
    LinBytesPerScanLine: 3200
    BnkNumberOfImagePages: 7
    LinNumberOfImagePages: 7
    LinRedMaskSize: 8
    LinGreenMaskSize: 8
    LinBlueMaskSize: 8
    LinRsvdMaskSize: 8
Mode: 101 (640x480)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 640
    XResolution: 640
    YResolution: 480
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 8
    NumberOfBanks: 1
    MemoryModel: 4
    BankSize: 0
    NumberOfImages: 49
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    LinBytesPerScanLine: 640
    BnkNumberOfImagePages: 49
    LinNumberOfImagePages: 49
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
Mode: 103 (800x600)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 800
    XResolution: 800
    YResolution: 600
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 8
    NumberOfBanks: 1
    MemoryModel: 4
    BankSize: 0
    NumberOfImages: 35
    RedMaskSize: 0
    RedFieldPosition: 0
    GreenMaskSize: 0
    BlueMaskSize: 0
    RsvdMaskSize: 0
    LinBytesPerScanLine: 800
    BnkNumberOfImagePages: 35
    LinNumberOfImagePages: 35
    LinRedMaskSize: 0
    LinGreenMaskSize: 0
    LinBlueMaskSize: 0
    LinRsvdMaskSize: 0
*Mode: 111 (640x480)
    WinAAttributes: 0x7
    WinBAttributes: 0x0
    WinGranularity: 64
    WinSize: 64
    WinASegment: 0xa000
    WinBSegment: 0x0
    BytesPerScanline: 1280
    XResolution: 640
    YResolution: 480
    XCharSize: 8
    YCharSize: 16
    NumberOfPlanes: 1
    BitsPerPixel: 16
    NumberOfBanks: 1
    MemoryModel: 6
    BankSize: 0
    NumberOfImages: 27
    RedMaskSize: 5
    GreenMaskSize: 6
    BlueMaskSize: 5
    RsvdMaskSize: 0
    LinBytesPerScanLine: 1280
    BnkNumberOfImagePages: 27
    LinNumberOfImagePages: 27
    LinRedMaskSize: 5
    LinGreenMaskSize: 6
    LinBlueMaskSize: 5
    LinRsvdMaskSize: 0
(II) VESA(0): Total Memory: 253 64KB banks (16192kB)
(II) VESA(0): Monitor0: Using hsync range of 30.00-75.00 kHz
(II) VESA(0): Monitor0: Using vrefresh range of 55.00-70.00 Hz
(II) VESA(0): Not using mode "1280x800" (no mode of this name)
(II) VESA(0): Not using mode "1280x768" (no mode of this name)
(--) VESA(0): Virtual size is 1024x768 (pitch 1024)
(**) VESA(0): *Built-in mode "1024x768"
(**) VESA(0): *Built-in mode "800x600"
(**) VESA(0): Built-in mode "640x480"
(++) VESA(0): DPI set to (96, 96)
(II) VESA(0): Attempting to use 70Hz refresh for mode "1024x768" (117)
(II) VESA(0): Attempting to use 60Hz refresh for mode "800x600" (114)
(II) VESA(0): Attempting to use 60Hz refresh for mode "640x480" (111)
(**) VESA(0): Using "Shadow Framebuffer"
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/lib/xorg/modules//libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
    ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
(II) Reloading /usr/lib/xorg/modules//libint10.so
Graphics Controller
(II) VESA(0): Splitting WC range: base: 0xe8000000, size: 0xfd0000
(II) VESA(0): Splitting WC range: base: 0xe8800000, size: 0x7d0000
(II) VESA(0): Splitting WC range: base: 0xe8c00000, size: 0x3d0000
(II) VESA(0): Splitting WC range: base: 0xe8e00000, size: 0x1d0000
(II) VESA(0): Splitting WC range: base: 0xe8f00000, size: 0xd0000
(II) VESA(0): Splitting WC range: base: 0xe8f80000, size: 0x50000
(==) VESA(0): Write-combining range (0xe8fc0000,0x10000)
(==) VESA(0): Write-combining range (0xe8f80000,0x50000)
(==) VESA(0): Write-combining range (0xe8f00000,0xd0000)
(==) VESA(0): Write-combining range (0xe8e00000,0x1d0000)
(==) VESA(0): Write-combining range (0xe8c00000,0x3d0000)
(WW) VESA(0): Failed to set up write-combining range (0xe8800000,0x7d0000)
(WW) VESA(0): Failed to set up write-combining range (0xe8000000,0xfd0000)
(II) VESA(0): virtual address = 0xb69e6000,
    physical address = 0xe8000000, size = 16580608
(==) VESA(0): Backing store disabled
(**) Option "dpms" "true"
(**) VESA(0): DPMS enabled
(WW) VESA(0): Option "UseInternalAGPGART" is not used
(WW) VESA(0): Option "XAANoOffscreenPixmaps" is not used
(WW) VESA(0): Option "DmaMode" is not used
(WW) VESA(0): Option "CursorShadow" is not used
(WW) VESA(0): Option "CursorShadowAlpha" is not used
(WW) VESA(0): Option "CursorShadowYOffset" is not used
(WW) VESA(0): Option "CursorShadowXOffset" is not used
(WW) VESA(0): Option "FlatPanelProperties" is not used
(WW) VESA(0): Option "NoLogo" is not used
(WW) VESA(0): Option "UseEDID" is not used
(WW) VESA(0): Option "AddARGBGLXVisuals" is not used
(WW) VESA(0): Option "RenderAccel" is not used
(WW) VESA(0): Option "TwinView" is not used
(WW) VESA(0): Option "SecondMonitorVendorName" is not used
(WW) VESA(0): Option "SecondMonitorModelName" is not used
(WW) VESA(0): Option "SecondMonitorHorizSync" is not used
(WW) VESA(0): Option "SecondMonitorVertRefresh" is not used
(WW) VESA(0): Option "TwinViewOrientation" is not used
(WW) VESA(0): Option "ConnectedMonitor" is not used
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) AIGLX: Screen 0 is not DRI capable
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "it"
(**) Keyboard0: XkbLayout: "it"
(WW) Option "XkbOptions" requires an string value
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(**) Option "Protocol" "auto"
(**) PS/2 Mouse: Device: "/dev/psaux"
(**) PS/2 Mouse: Protocol: "auto"
(**) Option "CorePointer"
(**) PS/2 Mouse: always reports core events
(**) Option "Device" "/dev/psaux"
(**) Option "Buttons" "5"
(**) Option "Emulate3Buttons" "false"
(**) Option "Emulate3Timeout" "70"
(**) Option "ZAxisMapping" "4 5"
(**) PS/2 Mouse: ZAxisMapping: buttons 4 and 5
(**) PS/2 Mouse: Buttons: 9
(**) PS/2 Mouse: Sensitivity: 1
(II) Synaptics touchpad driver version 0.14.6 (1406)
(--) Touchpad auto-dev sets device to /dev/input/event6
(**) Option "Device" "/dev/input/event6"
(**) Option "SHMConfig" "on"
(**) Option "LeftEdge" "1700"
(**) Option "RightEdge" "5300"
(**) Option "TopEdge" "1700"
(**) Option "BottomEdge" "4200"
(**) Option "VertScrollDelta" "100"
(**) Option "HorizScrollDelta" "0"
(**) Option "FingerLow" "25"
(**) Option "FingerHigh" "30"
(**) Option "MaxTapTime" "180"
(**) Option "MaxTapMove" "220"
(--) Touchpad touchpad found
(**) Option "SendCoreEvents"
(**) Touchpad: always reports core events
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (PS/2 Mouse)
(II) XINPUT: Adding extended input device "PS/2 Mouse" (type: MOUSE)
(II) evaluating device (Touchpad)
(II) XINPUT: Adding extended input device "Touchpad" (type: MOUSE)
(--) PS/2 Mouse: PnP-detected protocol: "ExplorerPS/2"
(II) PS/2 Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/cyrillic, removing
from list!
Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled,
removing from list!
Could not init font path element /usr/share/fonts/X11/Type1, removing
from list!
Could not init font path element /usr/share/fonts/X11/75dpi, removing
from list!
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!
(--) SynPS/2 Synaptics TouchPad auto-dev sets device to /dev/input/event6
(--) SynPS/2 Synaptics TouchPad touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad"
(type: MOUSE)
(WW) SynPS/2 Synaptics TouchPad can't grab event device, errno=16
anche /var/log/auth.log mi interesserebbe...
lukas
attachment.htm (1.11 KB)
lukas
> Date: Fri, 16 Oct 2009 11:05:51 +0200
> From: vedla(a)yahoo.it
> To: lugbz-list(a)lugbz.org
> Subject: [Lugbz-list] problema login
error".
> Grazie
> Werner
Eccolo
Oct 16 10:55:30 mepisonia sshd[4829]: Server listening on :: port 22.
Oct 16 10:55:30 mepisonia sshd[4829]: Server listening on 0.0.0.0 port 22.
Oct 16 10:56:33 mepisonia sshd[4829]: Received signal 15; terminating.
Oct 16 10:56:33 mepisonia sshd[5241]: Server listening on :: port 22.
Oct 16 10:56:33 mepisonia sshd[5241]: Server listening on 0.0.0.0 port 22.
Oct 16 11:03:21 mepisonia sshd[4536]: Server listening on :: port 22.
Oct 16 11:03:21 mepisonia sshd[4536]: Server listening on 0.0.0.0 port 22.
Oct 16 11:04:23 mepisonia sshd[4536]: Received signal 15; terminating.
Oct 16 11:04:23 mepisonia sshd[4945]: Server listening on :: port 22.
Oct 16 11:04:23 mepisonia sshd[4945]: Server listening on 0.0.0.0 port 22.
Oct 16 11:17:02 mepisonia CRON[5340]: pam_unix(cron:session): session
opened for user root by (uid=0)
closed for user root
Oct 16 11:32:22 mepisonia login[4850]: pam_lastlog(login:session): file
/var/log/lastlog created
Oct 16 11:32:22 mepisonia login[4850]: pam_unix(login:session): session
opened for user root by LOGIN(uid=0)
Oct 16 11:32:22 mepisonia login[5875]: ROOT LOGIN on 'tty1'
Oct 16 12:17:01 mepisonia CRON[7728]: pam_unix(cron:session): session
Oct 16 12:26:43 mepisonia sshd[4538]: Server listening on :: port 22.
Oct 16 12:26:43 mepisonia sshd[4538]: Server listening on 0.0.0.0 port 22.
Oct 16 12:27:46 mepisonia sshd[4538]: Received signal 15; terminating.
Oct 16 12:27:46 mepisonia sshd[4947]: Server listening on :: port 22.
Oct 16 12:27:46 mepisonia sshd[4947]: Server listening on 0.0.0.0 port 22.
Oct 16 12:27:47 mepisonia login[4853]: pam_unix(login:auth):
authentication failure; logname=LOGIN uid=0 euid=0 tty=tty1 ruser=
rhost= user=sonia
Oct 16 12:27:51 mepisonia login[4853]: FAILED LOGIN (1) on 'tty1' FOR
`sonia', Authentication failure
Oct 16 12:27:58 mepisonia login[4853]: pam_unix(login:session): session
opened for user sonia by LOGIN(uid=0)
Oct 16 12:29:41 mepisonia su[5090]: Successful su for root by sonia
Oct 16 12:29:42 mepisonia su[5090]: + tty1 sonia:root
Oct 16 12:29:42 mepisonia su[5090]: pam_unix(su:session): session opened
for user root by sonia(uid=1000)
Oct 16 13:17:01 mepisonia CRON[6919]: pam_unix(cron:session): session
Oct 16 13:39:08 mepisonia su[5090]: pam_unix(su:session): session closed
for user root
Oct 16 13:40:21 mepisonia sshd[4628]: Server listening on :: port 22.
Oct 16 13:40:21 mepisonia sshd[4628]: Server listening on 0.0.0.0 port 22.
Oct 16 13:41:08 mepisonia login[4945]: pam_unix(login:session): session
Oct 16 13:41:08 mepisonia login[5011]: ROOT LOGIN on 'tty1'
Oct 16 13:41:23 mepisonia sshd[4628]: Received signal 15; terminating.
Oct 16 13:41:23 mepisonia sshd[5059]: Server listening on :: port 22.
Oct 16 13:41:23 mepisonia sshd[5059]: Server listening on 0.0.0.0 port 22.
Oct 16 14:17:01 mepisonia CRON[6196]: pam_unix(cron:session): session
Oct 16 15:17:01 mepisonia CRON[8074]: pam_unix(cron:session): session
Oct 16 15:17:02 mepisonia CRON[8074]: pam_unix(cron:session): session
Oct 16 16:17:01 mepisonia CRON[9949]: pam_unix(cron:session): session
Oct 16 16:17:02 mepisonia CRON[9949]: pam_unix(cron:session): session
Oct 16 17:17:01 mepisonia CRON[11831]: pam_unix(cron:session): session
Oct 16 18:17:01 mepisonia CRON[13715]: pam_unix(cron:session): session
Oct 16 19:17:01 mepisonia CRON[15592]: pam_unix(cron:session): session
