RE: problemi a masterizzare con il kernel 2.6.8.
A questo proposito c'é un avvertimento sul sito di k3b: http://www.k3b.org/.
Paolo
<QUOTE>
Do not use Kernel 2.6.8
A patch that was introduced into the kernel shortly before the 2.6.8
release makes K3b and also the dvd+rw-tools unusable on Linux (unless
run as root but that is not recommended). The very important GET
CONFIGURATION MMC command is rejected by the kernel for reasons I cannot
see and writing commands like MODE SELECT also fail (K3b cannot detect
CD writers without it) even when the device is opened O_RDWR. Until this
issue has been solved I strongly recommend to stick to kernel version 2.6.7.
Update: The kernel guys are currently fixing the problem so the next
kernel release should work again. :slight_smile:
Update 2: The problem is NOT fixed in 2.6.8.1
Update 3: Be aware that kernel 2.6.8 also contains the memory leak which
makes it impossible to write audio cds, even as root.
</QUOTE>
Mi sa che continuero' ad usare il 2.6.7 :slight_smile:
Happy hacking e grazie a tutti!
