scheda grafica Intel 945GM
ciao a tutti, mi risulta la seguente scritta quando lancio glxgears per
esempio. ecco cosa mi dice:
"libGL warning: 3D driver claims to not support visual 0x5b"
il mio glxinfo è:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_OML_swap_method,
    GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
    GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
    GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
    GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
    GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) 945GM 20050225
OpenGL version string: 1.3 Mesa 6.5.1
OpenGL extensions:
    GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters,
    GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
    GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_clip_volume_hint, GL_EXT_cull_vertex,
GL_EXT_compiled_vertex_array,
    GL_EXT_convolution, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
    GL_EXT_fog_coord, GL_EXT_histogram, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
    GL_3DFX_texture_compression_FXT1, GL_APPLE_client_storage,
    GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_INGR_blend_func_separate, GL_MESA_pack_invert,
GL_MESA_ycbcr_texture,
    GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
    GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_NV_vertex_program,
    GL_NV_vertex_program1_1, GL_OES_read_format, GL_SGI_color_matrix,
    GL_SGI_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp,
    GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
    GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
per esempio. ecco cosa mi dice:
se usi Mandriva vedi un po' qui:
http://qa.mandriva.com/show_bug.cgi?id=26082
Esiste un update per questo problema:
http://www.mandriva.com/security/advisories?name=MDKA-2007:004
ciao,
andreas
