Ciao Roberto
robbe wrote:
[root(a)pepito root]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:10:B5:46:5C:81
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:229 errors:0 dropped:0 overruns:0 frame:0
TX packets:257 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:19898 (19.4 Kb) TX bytes:19499 (19.0 Kb)
Interrupt:11 Base address:0xa800
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2316 errors:0 dropped:0 overruns:0 frame:0
TX packets:2316 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1873676 (1.7 Mb) TX bytes:1873676 (1.7 Mb)
ppp0 Link encap:Point-to-Point Protocol
inet addr:82.48.60.6 P-t-P:192.168.100.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:3 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:54 (54.0 b) TX bytes:54 (54.0 b)
Secondo me la linea e' up e sei collegato, altrimenti non dovresti avere
il ppp0
N.B. 192.168.1.1 è il modem ethernet Siemens Gigaset ADSL
[root(a)pepito root]# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
169.254.0.0 * 255.255.0.0 U 0 0 0 eth0
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
Mhm, ma quasto e' un modem o un router? Se e' un router OK, ma
altrimento penso di no. Non c'e' la possibilita' di scegliere il
collegamento ADSL come route di default come con un modem? No? Allore
dovresti mettere una route del genere
route add default dev ppp0
o simile, se non riccordo male. Almeno con il buon vecchio modem era cosi.
[root(a)pepito root]# cat /etc/resolv.conf
; generated by /sbin/dhclient-script
search home
nameserver 192.168.1.1
Strano, il modem non e' un nameserver. Metti gli IP dei nameserver di
Telecom Italia:
nameserver IP-DNS-primario
nameserver IP-DNS-secondario
[root(a)pepito root]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain RH-Firewall-1-INPUT (0 references)
Piu' che vuoto
Karl
