Volevo avvisare chi cercasse di collegarsi al sito www.lugbz.org per le
prossime ore che potrebbe non trovarlo funzionante. Ci stiamo lavorando,
quindi non occorre che ce lo segnaliate. Grazie
Daniele
P.S. Gli altri servizi web-based dovrebbero comunque funzionare senza
intoppi.
--- snip ---
<h2>Site Error</h2> <p>An error was encountered while publishing
this resource.
</p>
<p><strong>NotFound</strong></p>
Sorry, a site error occurred.<p><p>Traceback (innermost last):
<ul>
<li> Module ZPublisher.Publish, line 194, in
publish_module_standard</li>
<li> Module Products.PlacelessTranslationService.PatchStringIO, line
34, in new_publish</li>
<li> Module ZPublisher.Publish, line 146, in publish</li>
<li> Module Zope2.App.startup, line 222, in
zpublisher_exception_hook</li>
<li> Module ZPublisher.Publish, line 106, in publish</li>
<li> Module ZPublisher.BaseRequest, line 323, in traverse</li>
<li> Module webdav.NullResource, line 66, in __bobo_traverse__</li>
</ul>NotFound: The requested resource was not found. (Also, the
following error occurred while attempting to render the standard error
message, please see the event log for full details: You are not allowed
to access 'aq_inner' in this context)
--- snip ---
